Sony H.ear On 2 Battery Replacement
Выберете то, что вам нужно
  1. Sony H.ear On 2 Battery Replacement, Battery: шаг 1, изображение 1 из 2 Sony H.ear On 2 Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Start by inserting the iFixit plastic opening tool into the crease between the hard plastic and the ear cup on the right side of the headphones. Then you should gently apply pressure until it separates.
    • You may need to repeat the process on the back using your hands or the iFixit plastic opening tool until it separates completely.
    • This may take a considerable amount of pressure but do not force it.
  2. Sony H.ear On 2 Battery Replacement: шаг 2, изображение 1 из 2 Sony H.ear On 2 Battery Replacement: шаг 2, изображение 2 из 2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cover off to reveal the internal components of the right ear cup.
    • There is a ribbon cable connecting the plastic cover to the battery housing on the headphones. Be wary not to damage this cable during disassembly by lifting the cap forcefully.
  3. Sony H.ear On 2 Battery Replacement: шаг 3, изображение 1 из 2 Sony H.ear On 2 Battery Replacement: шаг 3, изображение 2 из 2
    • Using the iFixit opening tools, gently separate the battery from the housing
    • The ribbon cable connecting the plastic cover to the battery housing is short, so make sure to move the plastic cover out of the way safely
    • The battery is adhered to the housing with epoxy. When removing the battery be aware that separation may require a bit of force.
    • Be careful not to damage the battery contacts during removal.
Заключение
13 участников успешно повторили данное руководство.
Braden Michelson
Участник с: 04/15/19
378 Репутация
1 руководство автора
Команда
Cal Poly, Team S9-G11, Maness Spring 2019 Участник Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 членов
Автор 16 руководств
4 Комментариев
Hi Braden!
Thanks for this manual looks easy. What is the best shop to buy a spare battery? Can you use the Sony SP 624038 ? It has slightly different specs (3.7 v instead 3.6v and 1000 mha instead of 925 mha). Would be an interesting upgrade.
Regards,
Marvin
Marvin Martens - Ответить
Since I could not find an SP70A battery, I ended up replacing the battery with an authentic SP70 battery that was rated at the same 925mAh and 3.6V.
Virgilio Sandoval -
Not easy! He doesn't mention that all the wires and battery plug are bundled and wrapped with thick sticky black tape. I tried cutting it with small surgical scissors and since it is blind cutting, cut a couple of wires. Headphones are ruined now.
Steve Bailey - Ответить
Thanks to you I have replaced the battery but seems like the new battery isn't holding the power as well - originally a water damage but the charging works and the headphone worked with aux and the old and new battery holds power somewhere between 4-6 hours. Is there a ground pin or something else that is leaking the charge?
vp08888 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 37
За последние 30 дней: 199
За всё время: 12,057
