Введение
This guide will explain how to take off the ear cups on the H.ear On 2 headphones. These steps can be applied to both the right and left side of the headphones. This guide is relatively easy and is necessary to complete other guides.
Выберете то, что вам нужно
Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
Еще один человек закончил это руководство.
