Введение
Learn how to replace the motherboard on your Sony H.ear On 2 headphones!
This guide focuses on replacing the motherboard component located in the left ear cup. This guide will require soldering and desoldering. Please see How To Solder and Desolder Connections before you attempt to desolder and resolder necessary on the components. Although optional, it is recommended you remove the battery before operating on the device for safety reasons.
Выберете то, что вам нужно
Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
