Sony HDR-AS30V LCD Screen Replacement
Выберете то, что вам нужно
  1. Sony HDR-AS30V LCD Screen Replacement, Outer Casing: шаг 1, изображение 1 из 1
    • Power off the device. Remove the component jack cover.
    • Open component door.
    • Using the Phillips 00 screwdriver, remove the two screws holding the jack cover in place.
  2. Sony HDR-AS30V LCD Screen Replacement: шаг 2, изображение 1 из 1
    • Open the battery door.
    • Slide the battery cap along the length of the camera, then flip the cap outward. Use caution; there may be internal damage affecting the functionality of the sliding mechanism.
  3. Sony HDR-AS30V LCD Screen Replacement: шаг 3, изображение 1 из 1
    • Prepare to remove outer casing.
    • Using the 2.5 mm precision slotted screwdriver, insert the tip of the screwdriver under the holder to wedge. Use caution when preparing to wedge apart fragile components.
  4. Sony HDR-AS30V LCD Screen Replacement: шаг 4, изображение 1 из 1
    • Separate Casing from Device.
    • With the screwdriver wedged, apply slight force while pulling the casing away from the device. Use caution to avoid causing damage to fragile parts.
  5. Sony HDR-AS30V LCD Screen Replacement: шаг 5, изображение 1 из 1
    • With the outer casing pulled away from the device, take note of the orientation of the inner component to avoid an electrical short.
    • Once the orientation of the inner component is noted, slide the inner component out of the casing. You may now replace the broken casing with a new one.
  6. Sony HDR-AS30V LCD Screen Replacement, LCD Screen: шаг 6, изображение 1 из 1
    • Remove two screws with the PH000 screwdriver.
    • Pop off plastic holder.
  7. Sony HDR-AS30V LCD Screen Replacement: шаг 7, изображение 1 из 1
    • With the flathead screwdriver, wedge under area shown and pop upwards.
    • Be sure to move the flex cable out of the way while flipping the plastic inner casing upward.
  8. Sony HDR-AS30V LCD Screen Replacement: шаг 8, изображение 1 из 1
    • Gently push speaker out of slot
  9. Sony HDR-AS30V LCD Screen Replacement: шаг 9, изображение 1 из 1
    • Flip open screen and make sure no cables are in the way.
  10. Sony HDR-AS30V LCD Screen Replacement: шаг 10, изображение 1 из 1
    • With the flathead, lift up cable lock and pull the film out from underneath the lock.
  11. Sony HDR-AS30V LCD Screen Replacement: шаг 11, изображение 1 из 1
    • Gently pull out screen.
Заключение
Dylan Keiter
Участник с: 01/28/15
101 Репутация
1 руководство автора
Команда
Penn State, Team 2-12, Kaschak Winter 2015 Участник Penn State, Team 2-12, Kaschak Winter 2015
PSU-KASCHAK-W15S2G12
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 506
