Введение
Occasionally the LCD screen or the Back light on the camera will be cracked or simply stop working. This page outlines how to disassemble the camera in order to install replacement parts for any broken pieces.
Выберете то, что вам нужно
On the back of the camera beneath the viewfinder, locate the battery pack.
Press the small button.
Slide the switch forward.
Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
Remove the three 4.5 mm screws beneath the battery.
Remove the 2.9 mm screw from the right corner.
Remove the two 4.5 mm screws from the battery's right wall.
Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
Remove the two 4.5 mm screws at the top of the camera.
Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
Gently pull apart the outer silver case and screen.
Remove the copper wire strip to detach the case from the camera.
Remove the copper strip from the housing that connects the outer casing to the entire of the camera.
Remove (4) 2.9mm screws from the L-shaped circuit board. They are marked with red circles in the slide.
Remove the (3) wire strips connected to the camera so you can pull off the L-shaped circuit board.
Remove the single wire strip that is connected to the bottom of the circuit board.
Remove the (2) 4.5mm screws.
Remove the small black holder from above the base of the LCD screen.
Remove the silver and black, front and back casings from the base of the screen.
Remove one copper strip from the inside of the bottom case.
Remove (2) 5.4mm screws that are securing the screen to the cover, from the base of the LCD.
Pull off the silver cover on the screen, which will reveal the circuit board from behind the screen itself.
Pull off the black tape stuck to both sides of the circuit board.
Remove the (3) copper strips to remove both the screen and the back light.
Replace what is broken.
Еще один человек закончил это руководство.
