Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide details the steps necessary to replace the LCD screen on a Sony Handycam DCR-HC30. This can be a fairly complex replacement if the correct tools are not used.
  1. To begin, the LCD screen must be removed. Bring the LCD screen to the fully open position.
    • To begin, the LCD screen must be removed.
    • Bring the LCD screen to the fully open position.
    • Remove the three 5 MM Phillips #1 screws on the front of the LCD screen.
  2. Flip the camera with the lens facing up. Turn the LCD screen so you can see the 5 MM Phillips #1 screw on the inside; remove the screw. Spin the LCD screen around to get the 5 MM Phillips #1 screw in the same place on the other side.
    • Flip the camera with the lens facing up.
    • Turn the LCD screen so you can see the 5 MM Phillips #1 screw on the inside; remove the screw.
    • Spin the LCD screen around to get the 5 MM Phillips #1 screw in the same place on the other side.
    • Use the plastic opening tool to gently separate the back of the screen from the unit.
  3. These parts are very small and fragile and can break easily. With the back off, spin the LCD screen back around. Using the plastic opening tool, gently lift up the holder that keeps the ribbon in place.
    • These parts are very small and fragile and can break easily.
    • With the back off, spin the LCD screen back around.
    • Using the plastic opening tool, gently lift up the holder that keeps the ribbon in place.
    • Gently slip the ribbon from its housing.
    • When this step is completed the LCD screen will separate from the rest of the camera. From here on you will only be working with the screen.
  4. Ensure that you are gentle when handling the parts of the board within. Even small mistakes can permanently damage the board. While holding the entire LCD screen unit in the palm of your hand use your thumb and forefinger to grasp the big ribbon and gently wiggle it out of its housing. Remove the one screw that holds the board onto the back of the LCD screen unit.
    • Ensure that you are gentle when handling the parts of the board within. Even small mistakes can permanently damage the board.
    • While holding the entire LCD screen unit in the palm of your hand use your thumb and forefinger to grasp the big ribbon and gently wiggle it out of its housing.
    • Remove the one screw that holds the board onto the back of the LCD screen unit.
  5. Using tweezers, gently wiggle the locks up and out on the ribbon housings of the three ribbons still connected to the LCD board. Slip the ribbons out of their housings. Slip the ribbons out of their housings.
    • Using tweezers, gently wiggle the locks up and out on the ribbon housings of the three ribbons still connected to the LCD board.
    • Slip the ribbons out of their housings.
  6. Within the LCD unit there are three layers to remove. While holding the ribbons back with your thumb remove the board and set in a safe place. Keeping the ribbons to the side remove the LCD filter. This exposes the LCD screen.
    • Within the LCD unit there are three layers to remove.
    • While holding the ribbons back with your thumb remove the board and set in a safe place.
    • Keeping the ribbons to the side remove the LCD filter. This exposes the LCD screen.
  7. Remove the LCD screen. Be sure to clean the new screen with a microfiber cloth before re-installation.
    • Remove the LCD screen.
    • Be sure to clean the new screen with a microfiber cloth before re-installation.
Заключение
Еще один человек закончил это руководство.
Matthew Hurt
Участник с: 15.01.2015
493 Репутация
Автор 3 руководств
Команда
USF Sarasota-Manatee, Team 1-2, Stewart Winter 2015 Участник USF Sarasota-Manatee, Team 1-2, Stewart Winter 2015
USFSM-STEWART-W15S1G2
4 членов
Автор 7 руководств
Один комментарий
What can be done if one of the locks get broken when wiggled. What is the name of the part I need to buy. Thanks
Fab - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 19
За всё время: 880
