Sony Handycam DCR-SR 47 Flex Cable Replacement
Выберете то, что вам нужно
  1. Sony Handycam DCR-SR 47 Flex Cable Replacement, Hard Drive: шаг 1, изображение 1 из 1
    • Remove the battery.
    • Use Philips #000 screwdriver to remove the 3mm screw under the battery
    • *t is recommended that you wait One Hour after removing the battery before disassembling the rest of the camera
  2. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 2, изображение 1 из 1
    • Using the Phillips #000 screwdriver, remove all 6 of the 3mm screws located on the side of the camera.
    • This step seems unnecessary to initially find the Hard Drive, but will allow access to the attached flex cable
  3. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 3, изображение 1 из 1
    • Using the Phillips #000 tool, remove the three 3mm screws from under the LCD screen
  4. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 4, изображение 1 из 2 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 4, изображение 2 из 2
    • Using the Phillips #000 screwdriver, remove the one 3mm screw on the back of the camera
    • Pull away the back shell of the camera, exposing the hard drive.
  5. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 5, изображение 1 из 3 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 5, изображение 2 из 3 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 5, изображение 3 из 3
    • Gently pull the flex cable away from the hard drive. It should pop-off with minimal effort.
    • The black guard has been removed in the first picture. The guard does not need to be removed in order to reach hard drive and cable, but it does show the path that the cable takes
    • Once removing the flex cable, remove the plastic guard from the side of the hard drive.
  6. Sony Handycam DCR-SR 47 Flex Cable Replacement, Flex Cable: шаг 6, изображение 1 из 2 Sony Handycam DCR-SR 47 Flex Cable Replacement, Flex Cable: шаг 6, изображение 2 из 2
    • Using the Phillips #000 screwdriver, remove the four screws from the housing under the hard drive.
    • Remove the top plastic housing of the camera. All screws attaching the housing have previously been removed.
  7. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 7, изображение 1 из 3 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 7, изображение 2 из 3 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 7, изображение 3 из 3
    • Using the Phillips #000 screwdriver, remove the two 3mm screws from the LCD Screen connector.
    • Remove the two 3mm screws that were exposed through the previous image
    • Carefully detach the LCD Screen from the rest of the camera.
  8. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 8, изображение 1 из 1
    • Carefully remove the lens covering from the camera in order to access the internal components
  9. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 9, изображение 1 из 2 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 9, изображение 2 из 2
    • Using the plastic opening tool, carefully separate the LCD Screen from the back covering
  10. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 10, изображение 1 из 1
    • Using the Philips #000 screwdriver, remove the single 3mm screw from the top of the camera. This removal will allow the microphone port covering to be removed
  11. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 11, изображение 1 из 1
    • Using the Phillips #000 screwdriver, remove the single 2mm screw from under the microphone port covering
  12. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 12, изображение 1 из 3 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 12, изображение 2 из 3 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 12, изображение 3 из 3
    • Using the spudger, gently remove the smaller flex cable connector from the LCD screen.
    • *You may also gently tug the flex cable using fingers if no opening tool is available*
    • Using the Phillips #000 screwdriver, remove the one 3mm screw connecting the LCD screen from the housing.
  13. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 13, изображение 1 из 2 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 13, изображение 2 из 2
    • Using the Phillips #000 screwdriver, remove the one 3mm screw from the speaker port
    • Detach the speaker and side of camera from the internal components
  14. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 14, изображение 1 из 2 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 14, изображение 2 из 2
    • Gently pull the flex cable out of the connector piece
    • *a spudger may be used if necessary*
  15. Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 15, изображение 1 из 2 Sony Handycam DCR-SR 47 Flex Cable Replacement: шаг 15, изображение 2 из 2
    • After removing the flex cable from the internal components, separate the LCD pivot arm housing from the flex cable using a spudger.
    • The old flex cable is now free and able to be switched with the new one.
Заключение
Ragan Whitlock
Участник с: 08/26/15
556 Репутация
Автор 4 руководств
Команда
Western Carolina University, Team 1-2, Virtue Fall 2015 Участник Western Carolina University, Team 1-2, Virtue Fall 2015
WCU-VIRTUE-F15S1G2
4 членов
Автор 8 руководств
Один комментарий
Please where i can buy the flexible cables to Sony?
Antonio - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 1,239
