Введение
Can't record or capture moments with a cracked lens? This guide will take you through removing the outer casing and removal and replacement of the lens module.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Unfasten the hand strap.
Place device on left side with front lens facing right.
Using a JIS size #00 precision Phillips screwdriver, unscrew the left middle 3mm Phillips screw.
Open the "DC IN" plastic tab (Second 3mm Phillips screw is revealed).
Unscrew the second 3mm Phillips screw.
Turn device over onto its top with the front lens facing right.
Unscrew the top left and top right 3mm Philips screws.
While securely holding the HDD in your left hand, use the soft pad of your right hand fingers to gently pull the ribbon wire out of its socket, toward your right.
Replace HDD.
On the bottom of the device, remove the right and middle bottom 3mm Philips screws.
Remove the panel.
On the right side of the device, remove the two black 3mm Philips screws.
Remove the grey tray by lifting out and away.
Using the pointed black spudger, carefully open the little black clasp on the large ribbon wire port.
Use the blunt tweezers to unplug the red and black wire by pulling out and away.
Unplug the small ribbon wire.
Unscrew the two right three 3mm Philips screws.
On the top of the device, unscrew the top right 3mm Philips screw.
On the left side of the device, unscrew the bottom left 3mm Philips screw.
On the left side of the device, unscrew the left middle 3mm Philips screw.
Carefully pivot the loose left side of the device until the ribbon wires are fully exposed.
Use the blunt tweezers to unplug the small orange ribbon wire.
Unplug the small white ribbon wire.
Set aside.
Use the blunt tweezers to unplug the blue ribbon wire.
Unplug the orange ribbon wire.
Use the blunt tweezers to unplug the orange ribbon wire.
Remove the top two black 3mm Philips screws.
To reassemble your device, follow these instructions in reverse order in addition to the HDD replacement guide.
