Введение
In this guide we well be removing the internal HDD of the DCR-SR68 Handycam and replacing it with a new one. This will involve removing some of the exterior casing to access the HDD.
Выберете то, что вам нужно
Undo Hand Strap
Get the iFixit screwdriver and remove the extension.
Use a JO Philips head bit.
Place device on left side with lens facing right.
Using the screwdriver, unscrew the left middle 3mm Philips screw.
Open the "DC IN" tabe. (Second 3mm Philips screw is revealed)
Unscrew this screw.
Turn device over onto it's top with the lens facing right.
Unscrew the top left and top right 3mm Philips screws.
Using your fingers, lift the HDD from it's right end, pivoting on it's left end.
Using your fingers, pull the black rubber bumpers off of the HDD.
Set the old HDD aside.
17 участников успешно повторили данное руководство.
7 Комментариев
What does the letter H after hte HDD1818 stands for?
My dcr-sr68 hdd not formting please find salution
My sony handycam DCR-SR68 HDD not formating plz find
