Введение
This guide will help to locate and remove the motherboard for replacement. This will involve removing a significant portion of the camera and wiring.
Выберете то, что вам нужно
Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
At this point, you should be able to remove the battery by simply lifting it from the camera.
Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
Use the Phillips #00 head to remove the following 5.5mm screws on the empty battery socket.
Fold back the hinging panel on the top of the camera located near the lens.
Use the Phillips #00 head to remove the following 5.5mm screws on the top under the hinging panel.
Slide back the cover for the DC and A/V ports on the right-hand side.
Use the Phillips #00 head to remove the following 5.5mm screws underneath the cover and on the right-hand side.
Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
Pull off the top casing by lightly grabbing either side and pulling towards the back of the camera.
Use the Phillips #00 head to remove the following 5.5mm screws on the inside of the top casing.
You are now free to remove the recording button, as well as its connection strip.
Use the Phillips #00 head to remove the following 5.5mm screws on the right-hand side near the lens.
Use the Phillips #00 head to remove the following 5.5mm screws on the top near the lens.
Carefully pop off the casing strip on the camera's left-hand side near the lens.
Use the Phillips #00 head to remove the following 5.5mm screws underneath the casing strip.
Carefully pull the lens cover and shutter assembly off of the front of the camera.
Use the Phillips #00 head to remove the following 5.5mm screws on the lens shell.
To begin removing the metal casing, use the Phillips #00 head to remove the following 5.5mm screws.
The camcorder's chip and part of the motherboard should naturally fall off at this point and should carefully be removed and placed to the side.
Use the Phillips #00 head to remove the following 5.5mm screws from the side of the motherboard.
Use the Phillips #00 head to remove the following 5.5mm screws and remove the lens compartment by carefully pulling it out of the metal casing.
Using a pair of tweezers, remove the ribbon cable connector attached to the metal casing and the motherboard.
Using a pair of tweezers, remove the following ribbon cable connectors to remove the motherboard from the camcorder.
Еще один человек закончил это руководство.
