Sony Handycam HDR-XR500V Hard Drive Replacement
Выберете то, что вам нужно
  1. Sony Handycam HDR-XR500V Hard Drive Replacement, Hard Drive: шаг 1, изображение 1 из 2 Sony Handycam HDR-XR500V Hard Drive Replacement, Hard Drive: шаг 1, изображение 2 из 2
    • Start at the bottom of the camera, where the threaded tripod mount is. There you will find two screws securing a plastic panel, one next to the Sony logo and the other under the push tab.
    • Remove the two 3mm Phillips #00 screws from this panel. Note that all screws mentioned in this assembly are 3mm Phillips #00 screws and thus only one tool is needed for this replacement.
  2. Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 2, изображение 1 из 2 Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 2, изображение 2 из 2
    • While the camera is oriented upside-down, locate the screw in the upper-right corner of the side opposite the LCD screen, under the strap and near the lens.
    • Remove the screw.
  3. Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 3, изображение 1 из 3 Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 3, изображение 2 из 3 Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 3, изображение 3 из 3
    • Locate the end of the Velcro strap under the harness.
    • Pull the Velcro strap away from camera towards the lens.
    • Pull the harness away from the camera to remove the strap.
  4. Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 4, изображение 1 из 1
    • Using your nails, pry open the MIC tab so it points away from the camera. You'll feel a tongue-and-groove locking mechanism under the raised opening tab that needs to be pressed inward to release.
  5. Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 5, изображение 1 из 2 Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 5, изображение 2 из 2
    • Under the MIC tab are two more Phillips-Head screws, one in between the red and green ports and one under the locking mechanism. Remove them both.
  6. Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 6, изображение 1 из 2 Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 6, изображение 2 из 2
    • Open AVR –HDMI tab by sliding the flat panel next to the "HDD" engraving towards the camera's lens.
  7. Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 7, изображение 1 из 2 Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 7, изображение 2 из 2
    • Under the AVR tab, on either side of the USB port and above the HDMI port, you will find two more screws. Remove them both.
  8. Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 8, изображение 1 из 2 Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 8, изображение 2 из 2
    • Hold the camera upright and, using your nail between the far right panel and the rest of the assembly, pry the hard drive open. If all screws were removed before this step, it should come away with very little effort.
  9. Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 9, изображение 1 из 3 Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 9, изображение 2 из 3 Sony Handycam HDR-XR500V Hard Drive Replacement: шаг 9, изображение 3 из 3
    • Pull the hard drive out from the compartment. You should know it by its silver raised sides and hexagon-patterned edges.
    • Insert the new hard drive in the same orientation as the one you just removed, i.e. manufacturer specs point inward and the silver outer casing faces the covering panel.
Заключение
To reassemble your device, follow these instructions in reverse order. Be sure to test your camcorder after assembly to ensure the new disk drive is compatible and operational.
4 участников успешно повторили данное руководство.
Rosalie Contreras
Участник с: 09/09/14
191 Репутация
1 руководство автора
Команда
CSU Fullerton, Team 2-5, Bruce Fall 2014 Участник CSU Fullerton, Team 2-5, Bruce Fall 2014
CSUF-BRUCE-F14S2G5
4 членов
Автор 2 руководств
2 Комментариев
My HD is fine so far but always wondered what I would do if it died. Thank You
John Frazzini - Ответить
Good tutorial. After replacing the damaged hard drive, there is no data for internal GPS maps (of course there was a warning in the factory service that this would be the case). I don't know where to download the map data and how to upload it. Somebody knows?
Jakub - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 7
За последние 30 дней: 19
За всё время: 2,964
