Введение
This step-by-step guide will allow you to follow along and replace the faulty speaker of your device.
Выберете то, что вам нужно
Using a Phillips #00 screwdriver, remove the four 14mm screws from the underside of the device.
Using the opening tool, gently pry the top portion from the side section of your device.
Using the Phillips #00 screwdriver, remove the two 14mm screws from the top of the motherboard.
Remove the Phillips #00 screw from the bottom of the white and blue box.
Remove the Phillips #00 screw from behind the white and blue box.
After unscrewing the white box, gently pull it out. This will allow for more room to access the speaker.
To separate the motherboard completely, you can cut the red and black wires that are attached to the speaker. This will allow you to access the speaker fully.
Use the plastic opening tool and the spudger to separate the speaker from the device by tracing its outline and loosening the glue.
Еще один человек закончил это руководство.
