Введение
If your Sony ICF-C1T alarm clock/radio is having issues with changing the station or playing the correct frequency, you may need to replace the tuner dial. Replacing the tuner dial on your radio will ensure that the alarm clock/radio can switch through different radio frequencies. Follow this guide for step-by-step instructions on replacing the tuner dial of your device.
Выберете то, что вам нужно
Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
Use the opening tool to pry apart the edges of the top and side portions of the device.
Remove the tuner dial by pulling it off of the motherboard. This can take a little force to remove.
