Введение
Use this guide to fix or replace a damaged antenna of a Sony ICF-P26 radio.
The antenna enables radios to get reception for their FM and AM bandwidth. A radio with no antenna or a damaged antenna would have distortion of radio waves .
Following these steps would fix the radio reception issues in a short time. There is minimal or no known danger associated with replacing the antenna .
Выберете то, что вам нужно
Use a mini screwdriver to remove the two screws from the battery compartment.
Gently insert an opening tool where the FM/AM/Off switch is, to force your way up.
Insert the opening tool in the other side where the volume and the earphone go.
Use the mini screwdriver to remove the screw holding the motherboard.
Unscrew the damaged antenna.
4 участников успешно повторили данное руководство.
2 Комментариев
Where would one acquire a compatible replacement antenna for this model of radio?
Thank you so much. The difficulty is opening the case. You explained it very well. My problem was the dirty potentiometer. I simply poured enough isopropyl alcool on it, to "wash" it, it flowed inside, turn it few times, that was all. Works as new. Thank you.
