Введение
This replacement guide was made for the Sony Extra Bass headphones, and if you are experiencing problems using the "swivel fold'' feature, these instructions can help solve that problem. There is a screw that holds the speaker to the headphones and with wear and tear the swivel action becomes less effective, replacement of the screw is necessary at this point. Be sure to check the headphones for other underlying problems before replacing the screw.
Выберете то, что вам нужно
Next, take out the screws that hold the front plate, using a J00 screwdriver.
Repeat for both the left and right screws.
Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
Repeat this process on both sides if necessary.
2 участников успешно повторили данное руководство.
