Введение
This replacement guide was made for the Sony Extra Bass headphones, and if you are experiencing distorted or fuzzy audio this replacement guide could be helpful. Over time, listening to music with the headphones causes the speakers to wear out. It is recommended to replace the speaker before any more damage is caused.
Инструменты
Запчасти
Детали не указаны.
Next, take out the screws that hold the front plate, using a J00 screwdriver.
Repeat for both the left and right screws.
Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
Repeat this process on both sides if necessary.
Begin by laying the headphones down flat on a surface.
Make sure that the headphone speakers are facing upward.
Using the plastic opening tools, gently pry the speaker from the headphone's base.
Use a J0 screw driver to unscrew the four screws located underneath on the cushion.
Simply pull away the speaker component to expose the under part of the speaker.
With the under part of the speaker exposed, remove the broken speaker from the wires and solder on the new speaker
Indicated on the image to the left shows the two points the speaker can be soldered
4 участников успешно повторили данное руководство.
Комментариев: 4
Hey Thanks for The speaker replacement information of Sony MDR-XB450AP Extra Bass Headphones and if you want to buy new headphone/earphoneplaease take a look at :
https://bestigeek.com/best-earphones-und...
Thanks
Regards
I really love this headphones, i have this headphone but in good condition not that type. but if you want to check new pair of headphones or earphones then here is the list
https://gadgetorg.com/best-headphones-un...
Regards
I have the same headphones and the left ear cup cables are completely detached that side also has the inline controls and mic so there are four wires i dont know what to do with the inline control wires
Where we get to buy sony headphones spaeker
