Введение
This guide will provide instruction for replacing the swivel plastic cover on the Sony Extra Bass headphones. This piece encases the swivel piece and can get damaged through wear and tear.
Выберете то, что вам нужно
Next, take out the screws that hold the front plate, using a J00 screwdriver.
Repeat for both the left and right screws.
Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
Repeat this process on both sides if necessary.
Еще один человек закончил это руководство.
