Введение
Replacing the lens mount requires removing any lens that is already attached then simply removing the casing of the lens mount.
Выберете то, что вам нужно
Hold lens and camera securely with two hands.
With the hand holding the camera, push down on the lens button. Twist the lens counterclockwise and pull out to release lens.
Using your screwdriver, remove the four (3.5 mm) Phillips screws on the front face of the lens mount.
Now the black plate should be exposed. You can remove this again by gently pinching with your fingers and lifting up.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using the tweezers, grab the thin silver ring and lift up.
Еще один человек закончил это руководство.
