Введение
The removal of the main navigation button involves removing the rear casing and carefully prying off the button as to not damage the sensitive components.
Выберете то, что вам нужно
Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
Using the spudger again, carefully pry from the top of the camera to remove the back frame.
The back frame is fragile, so use the spudger gently.
Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
3 участников успешно повторили данное руководство.
