Введение
The motherboard is the brains of the camera. Replacing the motherboard requires completely opening up the camera.
Выберете то, что вам нужно
Begin by holding the camera upside down with the bottom facing you. Identify the housing for the SD card, and battery.
You will use your other hand to slide the lock switch to this housing to the right. This will release the cap, allow it to come upwards.
Now that the cap to the battery and SD card housing is open, the SD card is visible.
You will need to press down on the SD card until you hear a click. Release the SD card and it will now be available to remove.
Grip the SD card and pull it out of the SD card slot.
To reinsert the SD card place it in its housing.
You will then need to push down on the SD card until you hear a click.
You may now close the housing for the SD card and battery.
Close the cap and while holding it down slide the locking tab to the left. This step should lock the cap in place.
Open the USB cover on the side of the camera.
Remove the 3.5 mm USB side screws.
Pry the top part rear cover off with plastic spudger.
Flip the camera so the sensor faces down and push up on the rear cover from the battery compartment.
Flip the rotary selector and controls up over the top.
Holding the controls in place, pull the two frame pieces apart.
Disconnect the connection between the motherboard and LCD screen by pulling out the connector in the direction of the arrow.
Using the tweezers, disconnect the metal lead at the top of the motherboard by pulling up.
Using the tweezers, flip open the black door on the large connector on the bottom.
Remove the connector by pulling it away from the motherboard.
Using the tweezers, flip open the door on the smaller connector.
With the tweezers, remove the metal speaker cover.
Pull the speaker out of the frame.
Flip the motherboard up and disconnect the connector on the back.
Seperate the motherboard from the frame.
