Введение
Use this guide to open the battery compartment and replace the battery.
If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
Flip the camera over such that the power switch points down.
Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
With the battery door open, push the blue lever in the battery compartment to release the battery.
To replace the battery, fit it in the slot, then close and lock the door.
2 участников успешно повторили данное руководство.
