Sony NEX-7 Lens Mount Replacement
Выберете то, что вам нужно
  1. Sony NEX-7 Lens Mount Replacement, Battery: шаг 1, изображение 1 из 2 Sony NEX-7 Lens Mount Replacement, Battery: шаг 1, изображение 2 из 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Lens Mount Replacement: шаг 2, изображение 1 из 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Lens Mount Replacement: шаг 3, изображение 1 из 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
  4. Sony NEX-7 Lens Mount Replacement, SD card: шаг 4, изображение 1 из 1
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
  5. Sony NEX-7 Lens Mount Replacement, Lens: шаг 5, изображение 1 из 2 Sony NEX-7 Lens Mount Replacement, Lens: шаг 5, изображение 2 из 2
    • First, turn the camera upside down.
    • Press the button located next to silver lens mount and rotate the lens counterclockwise.
    • Pull the lens away from the camera body.
    • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
  6. Sony NEX-7 Lens Mount Replacement, Lens Mount: шаг 6, изображение 1 из 1
    • With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
  7. Sony NEX-7 Lens Mount Replacement: шаг 7, изображение 1 из 1
    • Remove these three layers from the lens mount with your finger or by turning the camera face down.
  8. Sony NEX-7 Lens Mount Replacement: шаг 8, изображение 1 из 1
    • Remove the two newly visible #00 screws within the metal ring.
  9. Sony NEX-7 Lens Mount Replacement: шаг 9, изображение 1 из 1
    • Remove the final metal ring from the mount.
Заключение
5 участников успешно повторили данное руководство.
Jay Miley
Участник с: 04/22/14
5 064 Репутация
Автор 13 руководств
Команда
Cal Poly, Team 10-55, Amido Spring 2014 Участник Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 членов
Автор 31 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 29
За всё время: 2,231
