Sony NEX-7 SD card Replacement
  1. Sony NEX-7 SD card Replacement, Battery: шаг 1, изображение 1 из 2 Sony NEX-7 SD card Replacement, Battery: шаг 1, изображение 2 из 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 SD card Replacement: шаг 2, изображение 1 из 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 SD card Replacement: шаг 3, изображение 1 из 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
  4. Sony NEX-7 SD card Replacement, SD card: шаг 4, изображение 1 из 1
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
Заключение
To replace the SD card, press the card into the slot until it clicks. It will stay on its own. If it doesn't go in all the way, make sure the gold contacts are down and towards the battery door.
2 участников успешно повторили данное руководство.
Jay Miley
Участник с: 04/22/14
5 044 Репутация
Автор 13 руководств
Команда
Cal Poly, Team 10-55, Amido Spring 2014 Участник Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 членов
Автор 31 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 28
За всё время: 1,723
