Введение
When completing this guide, do not damage the processor or motherboard.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
Unscrew one 2.5 mm screw using a Phillips #00 screwdriver on bottom right portion of device located near audio jack.
Disconnect the headphone jack connection from the motherboard using any tool to remove black audio piece that needs to be replaced.
Еще один человек закончил это руководство.
