Введение
Underneath the metal platter, there are 2 plastic gears. These gears are used to move the tone arm while the turntable is on. If the tonearm is not moving properly during usage, these gear may be the problem. This guide shows how to replace them
Выберете то, что вам нужно
Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
Turn the platter so that the motor pulley can be seen through one of the two outer holes in the platter.
If the drive belt is hooked around the motor pulley, unhook it.
Peel the drive belt from the inner ridge of the metal platter and put it to the side.
Use screwdriver to remove the four Phillips #2 screws holding in the gears.
Remove the large gear.
Place the replacement small gear in its position.
Push and hold the metal knob close to the spring.
While holding the knob back, place the large gear inside with the open part of the gear facing away from the small gear.
Release the knob and spin the large gear counterclockwise.
To reassemble your device, follow solder the wire back, screw the gears back in, and step one in reverse order.
Еще один человек закончил это руководство.
Один комментарий
The directions in this guide work for the PS-LX310BT and the spindle assembly replacement part works with it as well. I can confirm this, I ordered a replacement spindle assembly because mine was bent and it worked perfectly.
