Введение
When working with electrical components, be sure to avoid loose wires.
Выберете то, что вам нужно
Locate the left side designation on the headband-earpiece junction.
The battery is in the right earpiece.
The motherboard is in the left earpiece.
Gently pull around the perimeter of the left ear cushion until it comes off.
Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
Gently pull the outer ear rim off of the headset assembly.
Using tweezers, gently pry the red and black speaker wires from the attached socket.
Lift up battery and disconnect wires using tweezers.
Use a new battery for reconstruction.
8 участников успешно повторили данное руководство.
7 Комментариев
Where can I buy the replacement battery for this?
Pretty hard to find...
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
