Sony Pulse Elite Edition Headband Replacement
Выберете то, что вам нужно
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: шаг 1, изображение 1 из 2 Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: шаг 1, изображение 2 из 2
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: шаг 2, изображение 1 из 2 Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: шаг 2, изображение 2 из 2
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: шаг 3, изображение 1 из 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: шаг 3, изображение 2 из 3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: шаг 3, изображение 3 из 3
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: шаг 4, изображение 1 из 1
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
Заключение
3 участников успешно повторили данное руководство.
Chris Echter
Участник с: 01/29/15
865 Репутация
Автор 4 руководств
Команда
Clemson, Team 14-2, Shirley Spring 2015 Участник Clemson, Team 14-2, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G2
5 членов
Автор 12 руководств
Один комментарий
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 26
За последние 30 дней: 88
За всё время: 5,838
