Введение
In our this guide, we will demonstrate how to replace the battery for the SONY RM-LVR1. This procedure consists of 3 simple steps. For optimal performance, fully charge the newly installed battery before use.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
If the screws strips or is previously stripped, refer to the stripped screw repair guide.
Battery is the rectangular and silver object in the center of device.
Remove battery with finger by prying at the rear.
If unable to remove battery, pry out using spudger.
3 участников успешно повторили данное руководство.
