Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement
Выберете то, что вам нужно
  1. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 2, изображение 1 из 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 3, изображение 1 из 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Battery: шаг 4, изображение 1 из 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 5, изображение 1 из 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Inner Casing: шаг 6, изображение 1 из 1
    • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
  7. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 7, изображение 1 из 1
    • Pry open the black casing to access the screw that is holding down the battery holder.
    • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
    • Lift the black inner casing and the battery holder out of the device.
    • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
  8. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Power Button: шаг 8, изображение 1 из 1
    • Remove the stylus from the device.
  9. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 9, изображение 1 из 3 Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 9, изображение 2 из 3 Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 9, изображение 3 из 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
  10. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, SD and Pro Duo Memory Cards Holder: шаг 10, изображение 1 из 1
    • Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the memory card holder.
  11. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 11, изображение 1 из 1
    • Using the flat end of the spudger, pry open the brown flap that connects the cardholder to the motherboard.
  12. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 12, изображение 1 из 2 Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: шаг 12, изображение 2 из 2
    • Pull the orange strip out of the opened brown flap.
    • Remove the memory card holder.
Заключение
Zachary Jeffers
Участник с: 10/13/14
412 Репутация
Автор 4 руководств
Команда
Clemson, Team 1-4, Benson Fall 2014 Участник Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 членов
Автор 22 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 16
За всё время: 343
