Sony SRS-X3 Auxiliary Port Replacement
Выберете то, что вам нужно
  1. Sony SRS-X3 Auxiliary Port  Replacement, Auxiliary Port Replacement: шаг 1, изображение 1 из 1
    • Remove the 6 philips head screws using the screwdriver and the PH1 bit
  2. Sony SRS-X3 Auxiliary Port  Replacement: шаг 2, изображение 1 из 1
    • Remove 5 philips head speakers holding in the battery and the green circuit board. 2 screws holding in the battery and 3 holding the circuit board.
  3. Sony SRS-X3 Auxiliary Port  Replacement: шаг 3, изображение 1 из 1
    • Pick out the battery pack and the green circuit board so that you can see the ribbon wire and the wire running from the battery pack to the circuit board.
  4. Sony SRS-X3 Auxiliary Port  Replacement: шаг 4, изображение 1 из 2 Sony SRS-X3 Auxiliary Port  Replacement: шаг 4, изображение 2 из 2
    • Remove the ribbon wire and the connector coming from the battery pack to the circuit board.
    • These connectors will not easily pull out, so you might have to give them a tug. They aren't very fragile, so don't worry about shredding them.
    • After this step, simply insert a new circuit board and you're done! Reassemble the speaker and start jamming!
Заключение
2 участников успешно повторили данное руководство.
Andrew Troyer
Участник с: 01/17/17
312 Репутация
Автор 2 руководств
Команда
Western Carolina University, Team 1-4, Virtue Spring 2017 Участник Western Carolina University, Team 1-4, Virtue Spring 2017
WCU-VIRTUE-S17S1G4
4 членов
Автор 5 руководств
5 Комментариев
Where did you buy the circuit board?
David Alvarez - Ответить
bad repair doesn't actually show replaceing port just circuit board and no info where to buy one.
munchy 22 - Ответить
Hi Andrew,
Can you tell me where I can purchase a replacement circuit board? I’m having trouble finding it online.
Part number is SONY 40BKB537U-CNF2G .
Thanks!
Julie Miller - Ответить
Where can I buy the circuit board and if you want me to buy it from you fine but tell us or tell me
Thanks
Jose reyes - Ответить
Donde puedo conseguir esas refacines
enriquereynahernandez423 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 16
За всё время: 1,818
