Sony SRS-X3 Battery Charging Port Replacement
Выберете то, что вам нужно
  1. Sony SRS-X3 Battery Charging Port Replacement, Battery Charging Port: шаг 1, изображение 1 из 1
    • Remove the 6 10mm Philips head screws shown, using a PH1 screwdriver
  2. Sony SRS-X3 Battery Charging Port Replacement: шаг 2, изображение 1 из 1
    • Remove the 5 8mm Philips head screws shown. These are holding the battery and the green circuit board in.
  3. Sony SRS-X3 Battery Charging Port Replacement: шаг 3, изображение 1 из 1
    • Lift the battery pack and circuit board out of the housing and locate the wires and ribbon connector shown in the figure.
  4. Sony SRS-X3 Battery Charging Port Replacement: шаг 4, изображение 1 из 2 Sony SRS-X3 Battery Charging Port Replacement: шаг 4, изображение 2 из 2
    • Remove the ribbon connector and the connector from the battery pack (Note: These connectors are not easy to remove. Force may be necessary but the connectors are durable)
    • After the connections are remove you are free to replace the circuit board.
Заключение
5 участников успешно повторили данное руководство.
bradley
Участник с: 01/17/17
233 Репутация
1 руководство автора
Команда
Western Carolina University, Team 1-4, Virtue Spring 2017 Участник Western Carolina University, Team 1-4, Virtue Spring 2017
WCU-VIRTUE-S17S1G4
4 членов
Автор 5 руководств
11 Комментариев
Bradley, this is a SONY 40BKB537U-CNF2G board….where can I get one? The mini charge port is bad on mine and v difficult to replace.
Thanks
michael ruse - Ответить
Where can I buy the whole circuit board to replace the Charging port
Sony Mini speaker SRS - X3
40BKB537U - CNF2G
charging port
Morgan -
Where can I buy circuit board To replace charging port Sony Mini speaker SRS - X3
40BKB537U-CNF2G
Morgan -
Hi Michael, did you find a replacement board? I need to replace mine as well.
Julie Miller -
I have all the part of this speaker. Email me to negotiate! Kennyportillo99@gmail.com
kennycontreras44 -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 23
За всё время: 6,654
