Введение
This guide demonstrates how to replace the USB/AUX board.
Выберете то, что вам нужно
To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
Remove the bottom panel of the speaker.
Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
Remove the battery.
To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
Unplug the cord connected to the motherboard by squeezing the plastic sides.
Gently tug on the plastic ribbon connected to the bottom side of the speaker to unplug it.
Using the Phillips #1 screwdriver, remove the two 6mm screws holding the AUX board in place.
Remove the aux board. Be careful as the board might need some wiggling to get out.
Еще один человек закончил это руководство.
2 Комментариев
hi there, where can i buy aux board for replacement? thank you
Donde puedo conseguir la tarjeta?
