Введение
Use this guide to replace the AM/FM chip, and follow it in reverse order to reinstall the new chip.
The AM/FM chip is necessary in order to be able to use the radio feature on your device,
Выберете то, что вам нужно
On the bottom of the device, you'll see 4 rubber pieces at the corners. Peel off these rubber pieces.
Unscrew the 4 10mm Philips J1 screws beneath them.
Poke through said stickers and unscrew the 2 10mm Philips J1 screws beneath those.
Insert the blue plastic tool into the corner of the bottom faceplate and slide along the edge.
Using a metal spudger, insert it into one of the corners or sides of the units faceplate and lightly pry open.
While pried, insert a plastic opening tool and slide along the edges of the unit.
Repeat the last step on each side of the unit's faceplate, until the faceplate is off.
With the faceplate now off, the speakers should be revealed. There should be 8 visible screws around the border of the speakers. Remove the 8 10mm Philips J1 screws.
Take the 2 20mm Philips J1 screws out of the middle of the speaker as shown.
Take the whole speaker out, and disconnect the connectors from the motherboard by lightly pulling on them.
Remove the two Philips J1 10mm screws from the top side and right side of the AM/FM chip.
Gently with your fingers, or a plastic grasping tool, remove the chip from the unit.
