Введение
This guide will show you how to disassemble the unit, which is universally the first step to starting all of the repair guides. The faceplate it the only thing in the way between you and the internal parts of the device. Without the faceplate on, you can repair literally anything in the device.
Выберете то, что вам нужно
On the bottom of the device, you'll see 4 rubber pieces at the corners. Peel off these rubber pieces.
Unscrew the 4 10mm Philips J1 screws beneath them.
Poke through said stickers and unscrew the 2 10mm Philips J1 screws beneath those.
Insert the blue plastic tool into the corner of the bottom faceplate and slide along the edge.
Using a metal spudger, insert it into one of the corners or sides of the units faceplate and lightly pry open.
While pried, insert a plastic opening tool and slide along the edges of the unit.
Repeat the last step on each side of the unit's faceplate, until the faceplate is off.
With the faceplate now off, the speakers should be revealed. There should be 8 visible screws around the border of the speakers. Remove the 8 10mm Philips J1 screws.
Take the 2 20mm Philips J1 screws out of the middle of the speaker as shown.
Take the whole speaker out, and disconnect the connectors from the motherboard by lightly pulling on them.
Еще один человек закончил это руководство.
