Выберете то, что вам нужно
To get the bottom part of the speaker off, take a long and sturdy screwdriver and put it through the holes at the bottom of the speaker.
When you have the screwdriver through the holes, you'll want to push down very firmly. Rotate between the holes and repeat this process until the bottom piece pops off.
You should see three 11 mm screws once the bottom of the device is off. Use a #1 Phillips screwdriver to remove these screws.
Place one end of the ifixit opening tool underneath the white bracket that sits above the motherboard, so that it latches onto the bottom side of the bracket.
With the opposite end of the tool, apply a gentle but firm downward motion to slowly pry the bracket from its position.
Locate the four 11 mm screws along the base of the white center block.
Use the Phillips #1 screwdriver with the 150mm flex extension from the Mako Driver kit to unscrew and remove the screws from their positions.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the blunt tweezers from the precision tweezers set to clamp down on a solid piece of the white center block.
With a firm grip, pull upwards with the blunt tweezers until the white center block is released from its position.
Locate the small brackets along the side of the white center block that hold the red, yellow, black, and white wires in place.
With your fingers, gently pull the wires away from the center block so that they are no longer held up by the brackets.
Flip the white center block over so that the black speaker is facing upwards.
Firmly grasp the speaker with your hands and pull it up and away from the center block until it fully disconnects from it.
Follow the red, yellow, and black cables to below the speaker.
Using the iFixit spudger, pry the battery from the case.
Еще один человек закончил это руководство.
