Sony SRS-XB40 Battery Replacement
Выберете то, что вам нужно
  1. Sony SRS-XB40 Battery Replacement, Speaker Assembly Replacement: шаг 1, изображение 1 из 1
    • Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
  2. Sony SRS-XB40 Battery Replacement: шаг 2, изображение 1 из 1
    • Remove the four T-8 screws (15 mm long) from the black speaker face.
  3. Sony SRS-XB40 Battery Replacement: шаг 3, изображение 1 из 1
    • Pry the two rubber end pieces loose enough to pry off two pieces of the long plastic casing from the speaker body using a metal spudger.
  4. Sony SRS-XB40 Battery Replacement: шаг 4, изображение 1 из 1
    • Pry the two remaining rubber pieces of the casing completely away from the body of the speaker with the same metal pry tool.
  5. Sony SRS-XB40 Battery Replacement: шаг 5, изображение 1 из 2 Sony SRS-XB40 Battery Replacement: шаг 5, изображение 2 из 2
    • Once you have removed the outer blue casing, four T-8 screws (15 mm long) will be revealed on each corner. After removing these screws, simply pull the top part of the speaker way from the body to get the the inner part of the speaker.
  6. Sony SRS-XB40 Battery Replacement: шаг 6, изображение 1 из 1
    • Once you have gotten to the internal parts of the speaker, there are seven wires connecting the speaker plate to the body of the speaker. Pinch the release tabs at the top of each of the four main wires to remove them.
  7. Sony SRS-XB40 Battery Replacement: шаг 7, изображение 1 из 3 Sony SRS-XB40 Battery Replacement: шаг 7, изображение 2 из 3 Sony SRS-XB40 Battery Replacement: шаг 7, изображение 3 из 3
    • Simply pull the thin wires on each side to remove them from their attachment points.
    • Remove the final red and black wire by gently pulling it apart.
    • This will ultimately detach the speaker plate from the base.
  8. Sony SRS-XB40 Battery Replacement, Battery: шаг 8, изображение 1 из 1
    • Unscrew the PH1 screw at the top of the speaker.
  9. Sony SRS-XB40 Battery Replacement: шаг 9, изображение 1 из 1
    • Slide the white protective case out of the speaker.
  10. Sony SRS-XB40 Battery Replacement: шаг 10, изображение 1 из 2 Sony SRS-XB40 Battery Replacement: шаг 10, изображение 2 из 2
    • Unplug the wire that connects the battery to the motherboard.
    • To remove the battery, peel away the tape that holds the battery in place.
Заключение
10 участников успешно повторили данное руководство.
Michael Shropshire
Участник с: 01/29/18
307 Репутация
1 руководство автора
Команда
University of Alabama, Team S1-G1, Bedsole Spring 2018 Участник University of Alabama, Team S1-G1, Bedsole Spring 2018
UA-BEDSOLE-S18S1G1
4 членов
Автор 6 руководств
11 Комментариев
Where can I purchase a replacement battery
andrewamenard - Ответить
Did you find the battery to this
jayrock.jo -
Brother you made my day…
I just finish your tutorial…thanks a
Pepe hernandez - Ответить
Hi Pepe, where do i get the wright Batterie, what was your exact artikel? U cant find the ones mentioned in the manual… Thank you!!
Johannes Tanz -
where can i purchase the new battery
ieezy naga - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 19
За последние 30 дней: 83
За всё время: 11,242
