Sony SRS-XB40 Motherboard Replacement
Выберете то, что вам нужно
  1. Sony SRS-XB40 Motherboard Replacement, Speaker Assembly Replacement: шаг 1, изображение 1 из 1
    • Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
  2. Sony SRS-XB40 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Remove the four T-8 screws (15 mm long) from the black speaker face.
  3. Sony SRS-XB40 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Pry the two rubber end pieces loose enough to pry off two pieces of the long plastic casing from the speaker body using a metal spudger.
  4. Sony SRS-XB40 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Pry the two remaining rubber pieces of the casing completely away from the body of the speaker with the same metal pry tool.
  5. Sony SRS-XB40 Motherboard Replacement: шаг 5, изображение 1 из 2 Sony SRS-XB40 Motherboard Replacement: шаг 5, изображение 2 из 2
    • Once you have removed the outer blue casing, four T-8 screws (15 mm long) will be revealed on each corner. After removing these screws, simply pull the top part of the speaker way from the body to get the the inner part of the speaker.
  6. Sony SRS-XB40 Motherboard Replacement: шаг 6, изображение 1 из 1
    • Once you have gotten to the internal parts of the speaker, there are seven wires connecting the speaker plate to the body of the speaker. Pinch the release tabs at the top of each of the four main wires to remove them.
  7. Sony SRS-XB40 Motherboard Replacement: шаг 7, изображение 1 из 3 Sony SRS-XB40 Motherboard Replacement: шаг 7, изображение 2 из 3 Sony SRS-XB40 Motherboard Replacement: шаг 7, изображение 3 из 3
    • Simply pull the thin wires on each side to remove them from their attachment points.
    • Remove the final red and black wire by gently pulling it apart.
    • This will ultimately detach the speaker plate from the base.
  8. Sony SRS-XB40 Motherboard Replacement, Motherboard: шаг 8, изображение 1 из 2 Sony SRS-XB40 Motherboard Replacement, Motherboard: шаг 8, изображение 2 из 2
    • Remove the PH-1 (10mm) screw from the top of the speaker that is connected to the motherboard.
  9. Sony SRS-XB40 Motherboard Replacement: шаг 9, изображение 1 из 3 Sony SRS-XB40 Motherboard Replacement: шаг 9, изображение 2 из 3 Sony SRS-XB40 Motherboard Replacement: шаг 9, изображение 3 из 3
    • Disconnect the wire from the motherboard.
    • Then remove the motherboard and white case from the speaker.
  10. Sony SRS-XB40 Motherboard Replacement: шаг 10, изображение 1 из 2 Sony SRS-XB40 Motherboard Replacement: шаг 10, изображение 2 из 2
    • Remove the wires connected to the back of the motherboard before removing the white cover.
  11. Sony SRS-XB40 Motherboard Replacement: шаг 11, изображение 1 из 2 Sony SRS-XB40 Motherboard Replacement: шаг 11, изображение 2 из 2
    • Remove the PH-1 screws (10 mm) from the motherboard to detach it from the outer white casing.
Заключение
3 участников успешно повторили данное руководство.
Price McGiffert
Участник с: 01/29/18
118 Репутация
1 руководство автора
Команда
University of Alabama, Team S1-G1, Bedsole Spring 2018 Участник University of Alabama, Team S1-G1, Bedsole Spring 2018
UA-BEDSOLE-S18S1G1
4 членов
Автор 6 руководств
4 Комментариев
This was a very informative breadown thanks. Im am looking to go further than this i am looking for the skhematic breadown of parts and resisters on the mother board. I have one that grounds out and wont come on so i just need to atlease be able to find the diodes on the board. Thanks again if ypu can help.
Rodney - Ответить
Indeed it is very informative, thanks for uploading these step details. I had to open up my same xb40 speaker coz it doesn’t start. When I pressed the power button the bluetooth light blinks for 2-3 sec and then it goes off along with the power light. So I showed the motherboard to the bluetooth speaker repair man, he told me the problem is with bluetooth chip without checking the circuit board. Can you further guide me on this please, where should i find the new motherboard, I live in India.
Xinu kumar - Ответить
Where can I get a motherboard for the SRS-XB40?
Mohammad Alhomsi - Ответить
Did you have any luck sourcing one?
maxhodg -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 23
За последние 30 дней: 66
За всё время: 3,796
