Sony Tablet S Battery Replacement
Выберете то, что вам нужно
  1. Sony Tablet S Battery Replacement, Battery: шаг 1, изображение 1 из 2 Sony Tablet S Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
    • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
  2. Sony Tablet S Battery Replacement: шаг 2, изображение 1 из 1
    • Remove the two 10mm Phillips #0 screws located under the grips.
  3. Sony Tablet S Battery Replacement: шаг 3, изображение 1 из 2 Sony Tablet S Battery Replacement: шаг 3, изображение 2 из 2
    • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
    • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
  4. Sony Tablet S Battery Replacement: шаг 4, изображение 1 из 1
    • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
  5. Sony Tablet S Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
    • Use caution when removing the cable, as the socket is very fragile.
  6. Sony Tablet S Battery Replacement: шаг 6, изображение 1 из 1
    • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
  7. Sony Tablet S Battery Replacement: шаг 7, изображение 1 из 1
    • Slide the bottom grey cover piece away from the body and remove it.
    • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
  8. Sony Tablet S Battery Replacement: шаг 8, изображение 1 из 1
    • Remove the five 4mm Phillips #000 screws.
    • Remove the two 5mm Phillips #000 screws holding the charger in place.
  9. Sony Tablet S Battery Replacement: шаг 9, изображение 1 из 3 Sony Tablet S Battery Replacement: шаг 9, изображение 2 из 3 Sony Tablet S Battery Replacement: шаг 9, изображение 3 из 3
    • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
    • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
  10. Sony Tablet S Battery Replacement: шаг 10, изображение 1 из 2 Sony Tablet S Battery Replacement: шаг 10, изображение 2 из 2
    • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
  11. Sony Tablet S Battery Replacement: шаг 11, изображение 1 из 1
    • Remove the three 5mm Phillips #0 screws securing the original battery.
  12. Sony Tablet S Battery Replacement: шаг 12, изображение 1 из 2 Sony Tablet S Battery Replacement: шаг 12, изображение 2 из 2
    • Use the spudger to pop the battery loose and remove the battery.
Заключение
4 человек успешно провели ремонт по этому руководству.
Austin Mann
Участник с: 09/28/16
287 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 3-5, Passmore Fall 2016 Участник USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
3 членов
Автор 5 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 26
За всё время: 3,011
