Sony VAIO VPCEC1M1E Keyboard Replacement
Выберете то, что вам нужно
  1. Sony VAIO VPCEC1M1E Keyboard Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Remove the following color-coded screws:
    • These screws secure the RAM and hard drive covers, respectively.
    • These screws secure the optical drive to the lower case of the laptop.
    • The various other screws highlighted in the picture are unnecessary to remove and should be done at your own discretion.
  2. Sony VAIO VPCEC1M1E Keyboard Replacement: шаг 2, изображение 1 из 1
    • Remove the following screws:
    • Five screws highlighted in orange.
    • Two screws highlighted in blue.
    • Pry the hard drive connector upwards from its socket on the logic board.
  3. Sony VAIO VPCEC1M1E Keyboard Replacement: шаг 3, изображение 1 из 1
    • Release the highlighted clips to remove the upper case of the keyboard.
  4. Sony VAIO VPCEC1M1E Keyboard Replacement: шаг 4, изображение 1 из 3 Sony VAIO VPCEC1M1E Keyboard Replacement: шаг 4, изображение 2 из 3 Sony VAIO VPCEC1M1E Keyboard Replacement: шаг 4, изображение 3 из 3
    • Flip up the retaining flap (highlighted in red) on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap and not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the laptop.
Финишная черта
7 участников успешно повторили данное руководство.
Stephan
Участник с: 08/20/11
199 Репутация
1 руководство автора
3 Комментариев
Very useful, thank you. A real pain to do though without snapping the plastic tabs on the upper case.
Eddie B - Ответить
OMG... guys, you need just unscrew FOUR screws on the bottom (two orange circles on the same level that yellow sticker and two orange-circled screws in the middle of left and right side) and then pop the keyboard up with knife, etc, and disconnect the cable.
Paul G - Ответить
agree with Paul G. you don’t need to remove all the plastic case to change the keyboard
Pierret -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 19
За всё время: 22,996
