Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows the repairing and replacing of the keyboard.
Выберете то, что вам нужно
Turn the laptop upside down so that the top is sitting on a flat surface.
If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
As shown by the arrow, slide the plastic cover up and then pull out and downwards.
You should now be able to pull the battery out.
Remove the four 16mm Phillips screws bordering the edge of the laptop, indicated here.
Remove the 4mm Phillips screw on the right rear side of the laptop next to the audio ports.
This will release the speaker grille.
Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
Carefully pull out the white electrical strip.
Remove the 4mm Phillips screw in the center (located to the left of the green strip).
Carefully pull the green strip straight up to disconnect it.
The keyboard can now be removed.
