Введение
Replacement steps for a hard disk drive in a Sony VAIO SVE14AJ16L Laptop.
Выберете то, что вам нужно
Remove the two screws on the hard drive cover with a Phillips #0 screwdriver.
Remove the hard drive cover.
Remove the two screws holding the hard drive in place with a Phillips #0 screwdriver.
Using the plastic tab, slide the hard drive out away from the main portion of the laptop.
Lift the hard drive out of the laptop using the tab.
Remove the four screws holding the hard drive bracket to the hard drive using a Phillips #0 screwdriver.
Еще один человек закончил это руководство.
