Введение
RAM replacement steps for a Sony VAIO SVE14AJ16L laptop.
Выберете то, что вам нужно
Turn the laptop upside down onto the closed lid so that the bottom is facing you.
Locate and remove the lone screw on the RAM cover with a Phillips #0 head screw driver.
Carefully pry the RAM cover up.
Инструмент, используемый на этом этапе:iFixit Opening Tool$1.99
With the cover removed, peel back the black protective plastic to expose one of the two RAM sticks.
Gently, but firmly push back the two side anchors that hold in the RAM using either an iFixit Opening Tool or your fingernails.
Finally, carefully pull the RAM stick away from the laptop at the same angle it is sitting at.
