Введение
If you find that your laptop no longer connects to a Wi-Fi connection. It may be time to replace the wireless network card.
Выберете то, что вам нужно
Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
Remove the 3 mm Phillips #0 screw from the wifi card.
Remove the card from its socket.
2 участников успешно повторили данное руководство.
