Sony VAIO VGN-FW 590 Keyboard Replacement
Выберете то, что вам нужно
  1. Sony VAIO VGN-FW 590 Keyboard Replacement, Battery: шаг 1, изображение 1 из 2 Sony VAIO VGN-FW 590 Keyboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 2, изображение 1 из 2 Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 2, изображение 2 из 2
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 3, изображение 1 из 2 Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 3, изображение 2 из 2
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
  4. Sony VAIO VGN-FW 590 Keyboard Replacement, Keyboard: шаг 4, изображение 1 из 1
    • Remove the circled screws using the Phillips #0 screwdriver.
    • The outer two screws are 7.7mm
    • The center two screws are 2.5mm
    • The bottom screw is 7.6mm
  5. Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 5, изображение 1 из 1
    • Open the computer
  6. Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 6, изображение 1 из 1
    • Remove the audio panel above the keyboard.
    • Lift one corner gently with a flat tool or fingernail.
    • Pull the rest of the panel gently out by hand.
  7. Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 7, изображение 1 из 1
    • Lift the keyboard gently, starting with one of the top corners.
    • Pull keyboard gently from body of computer to prevent warping or breakage.
    • Caution Do not remove completely.
  8. Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 8, изображение 1 из 3 Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 8, изображение 2 из 3 Sony VAIO VGN-FW 590 Keyboard Replacement: шаг 8, изображение 3 из 3
    • Locate the connector ribbon behind the keyboard.
    • Gently pull the ribbon from the locking device. It may take a few tries.
    • Caution Do not tear the ribbon.
Заключение
Jennifer Pache
Участник с: 10/30/17
304 Репутация
Автор 3 руководств
Команда
University of North Texas, Team S1-G3, Boettger Fall 2017 Участник University of North Texas, Team S1-G3, Boettger Fall 2017
UNT-BOETTGER-F17S1G3
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 1,047
