Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This will guide you in replacing the Media Board of a Sony Vaio VPCF 132FX
Запчасти
Детали не указаны.
  1. Remove all wires then flip the laptop
    • Remove all wires then flip the laptop
  2. Remove the battery Remove the battery
    • Remove the battery
  3. Remove the screws and flip it back.
    • Remove the screws and flip it back.
  4. Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it. Slide from the sides towards the center. Slide from the sides towards the center.
    • Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it.
    • Slide from the sides towards the center.
  5. Gently remove the wire of the Power Button.
    • Gently remove the wire of the Power Button.
  6. Unlock the Lock. Unscrew the 3 Flat screws and remove the Media Board. You may skip this step if replacing the Power Button.
    • Unlock the Lock.
    • Unscrew the 3 Flat screws and remove the Media Board.
    • You may skip this step if replacing the Power Button.
Заключение
Еще один человек закончил это руководство.
trickster
Участник с: 23.12.2013
2 061 Репутация
Автор 11 руководств
Один комментарий
What are the functions of the media board? My vaio vgn-fw170j won't power up (no LEDS on the power switch, or anywhere else, no fan, nothing). Verified that MoBo has 19.5 VDC on the board. Replaced MoBo and CPU, still no response. Since power button plugs into Media Board, figured it might be failed - any idea if this could be the cause?
course2kid - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 1,209
