1. Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer. Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer. Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Lift off back cover to access inner components of computer.
    • Lift off back cover to access inner components of computer.
  5. Remove the three 1mm Phillips #0 screws surrounding the fan. Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  6. Use tweezers to carefully unplug the fan connector. Use tweezers to carefully unplug the fan connector. Use tweezers to carefully unplug the fan connector.
    • Use tweezers to carefully unplug the fan connector.
  7. Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer. Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
Заключение
4 участников успешно повторили данное руководство.
Marii
Участник с: 08.01.2015
582 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 21-19, Maness Winter 2015 Member of Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 членов
Автор 6 руководств
Один комментарий
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - Ответить
Просмотр статистики:
За 24 часа: 2
За 7 дней: 7
За 30 дней: 36
За всё время: 3,451
