Введение
Laptop screen having connectivity issues? Need to replace the screen connection? Look no further!
Выберете то, что вам нужно
Flip over the screen
Remove all 8 screws as shown circled in the image using a Phillips #0
Flip the screen back over.
Use a plastic spudger to remove the top section of the cover.
Gently raise the metal framework of the laptop to reveal the remaining portion of the screen connector.
Follow the ribbon wiring to where it connects to the screen.
Carefully pull the wiring to disconnect and click it back in place to reconnect.
4 участников успешно повторили данное руководство.
5 Комментариев
Where to buy or to repair screen connector for Vaio Fit SVF13N13
Where to replace the keyboard of Vaio SVF13N2
Where i buy flexi
The procedure is nicely explained
Is there an option to replace the LCD flet cable ... ?
It is complicated but we found a defect on the flet cable.
I found some spareparts over the sony website. With all data from you laptop you can find them here https://uk.eetgroup.com/Guide/m/Sony-VAI...
