Введение
Screen cracked? Needs replacing? Look no further!
Выберете то, что вам нужно
Carefully remove each end of the connector strip from the back panel.
Feed the disconnected ribbon highlighted in blue through the slot in the metal frame.
Disconnect section of the screen connector highlighted in blue.
Gently pull up on the tape at the bottom of the ribbon to unplug the screen connector from the screen.
2 участников успешно повторили данное руководство.
