Введение
The fan is necessary to prevent the laptop from overheating. This guide will show you how to properly remove the fan component in the Sony Vaio Fit SVF15N26CXB. Use the project mat to keep the screws organized.
Запчасти
Детали не указаны.
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
Use a plastic opening tool to separate the bottom cover from the laptop.
Lift the lower cover and pull away from the laptop.
Remove the eight Phillips #00 screws from the battery:
Six 4.65mm screws.
Two 4.65mm screws.
Remove the four 4.58mm Phillips #00 screws from the cooling system.
Unscrew the five Phillips #00 screws from the heatsink.
2 участников успешно повторили данное руководство.
