Введение
If your computer in running slow it may be due to a hard drive error. This guide will show you how to replace the hard drive in your Sony Vaio PCG-16L.
Выберете то, что вам нужно
Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
Remove the 6 mm screw on the left side of the battery that holds the casing to the device using a phillips head screwdriver.
Turn the device upside down and remove the other 6 mm screw holding the casing to the device using a phillips head screwdriver.
The ribbon cable covering the hard drive and connecting to the motherboard is held in using zero insertion force (ZIF) connector.
Use the tip of a spudger or your fingernail to flip up the small retaining flaps, then pull the ribbon cable out.
Remove the ribbon cable connecting the motherboard to the hard drive by pulling the female connector off of the pins attached the hard drive.
Еще один человек закончил это руководство.
